Add Autoscroll to Drawing Model Browser
Hey! Working on multi-Sheet drawings, what would be excellent to see would be the addition of the AutoScroll check like the hamburger menu has in the Assembly model browser. having multiple sheets expanded and loosing where a certain view is being generated from, being able to instantly scroll to that item would be helpful!
3 Comments
bastien.dissaux
Same idea here : https://forums.autodesk.com/t5/inventor-ideas/auto-scroll-for-drawing/idi-p/12293934
I hope it will be implemented one day
SReitberger
Hi @Austin_Carpenter,
are you aware of the 'Find in Browser' command? If a drawing view is selected in the graphics window this command is available in the context menu. (the command is available for most of the selected items.) The command will highlight the selected view in the model browser. There is also a shortcut for this: Ctrl+B (by default).
This seems to be close to your idea (if i got it right - sorry if not).
best regards
Stephan
Austin_Carpenter
@SReitberger, Thank you so much!!!! this is amazing, I did not know this existed!
