Adaptable Notching on Frame Generator
I imagine this would be difficult to do, but here goes...
In frame generator, when notching dissimilar thickness sections into each other, a portion of the web/flange on the thicker section is left behind, where in real life this would be cut away. Would it be possible to allow Inventor to remove any remnants of section webs or flanges that run parallel to the direction of cut?
It would be even better if Inventor could also remove corner fillets, which, again in real life, would be cut/ground away.
I know it seems like a petty thing, but these webs and fillets that get left behind show up as unwanted hidden details on drawings, that have to be manually hidden. On large frameworks this can be very time-consuming.
Attached screenshots show typical examples
1 Comment
michel.beaulieuMR625
I will add one more.... If you change the part size of the part that does the notching, the notch does not change size?? You have to start all over again!!
