Acme Thread
Acme Thread
Would be nice to have Acme threading into the hole feature menu.
1 Comment
Diequa
Edit: the forum modified the formatting so if it doesn't make sense i could attach is as a downloadable link?
I needed to do with with trapezoidal lead screws, so I made one for ACME as well if i needed it, you can add the data below your thread spreadsheet in Design Data folder in a new tab, change the sort Order to whatever the next number in your list might be.
This was AI generated, the size and TPI it created was correct, but external and internet sizes might be off, the thread runouts were added in but i don't see why you would need those, so use with caution, you can add lines as well to add the other thread sizes.
I did vote for this hoping Autodesk could just add more thread designations.
I QACME Lead ScrewsSort Order -## External Internal
      Major DiaPitch DiaMinor Dia  Minor DiaPitch DiaMajor DiaTap DrillThread DepthThread Runouts
SizeSize SuffixThread DesignationCustom Thread DesignationTPIClassMaxMinMaxMinMaxMin ClassMinMaxMinMaxMinMaxBasic
1/4 1/4-161/4-16162G0.2500.2460.2300.2260.1980.193 2G0.1880.1980.2260.2300.2460.2500.1880.03130.0939
5/16 5/16-145/16-14142G0.31250.3080.2900.2860.2560.251 2G0.2460.2560.2860.2900.3080.31250.2460.03570.1071
3/8 3/8-123/8-12122G0.3750.3700.3500.3460.3100.305 2G0.2980.3100.3460.3500.3700.3750.2980.04170.1251
7/16 7/16-107/16-10102G0.43750.4320.4080.4040.3650.360 2G0.3550.3650.4040.4080.4320.43750.3550.05000.15
1/2 1/2-101/2-10102G0.5000.4950.4700.4650.4230.417 2G0.4090.4230.4650.4700.4950.5000.4090.05000.15
5/8 5/8-85/8-882G0.6250.6200.5900.5850.5300.524 2G0.5170.5300.5850.5900.6200.6250.5170.06250.1875
3/4 3/4-63/4-662G0.7500.7450.7100.7050.6400.635 2G0.6280.6400.7050.7100.7450.7500.6280.08330.2499
7/8 7/8-67/8-662G0.8750.8700.8350.8300.7650.760 2G0.7520.7650.8300.8350.8700.8750.7520.08330.2499
1 1-51-552G1.0000.9950.9600.9550.8800.875 2G0.8680.8800.9550.9600.9951.0000.8680.10000.3
1 1/8 1 1/8-51 1/8-552G1.1251.1201.0851.0800.9900.985 2G0.9780.9901.0801.0851.1201.1250.9780.10000.3
1 1/4 1 1/4-41 1/4-442G1.2501.2451.2101.2051.1051.100 2G1.0931.1051.2051.2101.2451.2501.0930.12500.375
1 1/2 1 1/2-31 1/2-332G1.5001.4951.4601.4551.3501.345 2G1.3381.3501.4551.4601.4951.5001.3380.16670.5001
