This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Ability to redefine dimensions
When working in a 2D sketch it would be very helpful if I were able to redefine dimensions. Currently if I have a dimension that was created, then named, checked for export, etc, then want to move what that dimension referenced (either due to a design change, or if I changed my mind about something, or if it was modeled incorrectly the first time, etc.) I have to delete that dimension and recreate it. This can become very tiresome if I have several dimensions that all need to be updated at the same time. It would be nice if I had a option to "Redefine Dimension", similar to redefining a plane, when I right clicked on the dimension so that I would not have to delete it and recreate it.
11 Comments
ic198
There is a workaround for this one. Say you have Dimension A that is exported but you need to redefine it. Create a Parameter B and make that equal to Dimension A. You can now delete Dimension A from your sketch- because it is used in Parameter B it will stay in your parameters list. Create your new Dimension C. In your parameters list make A equal to C. A will continue to export and will be the correct value. You can now delete B. I hope that's all easy to follow!
Being able to redefine dimensions would be better, but in the meantime the above might help
+1 for redefining dimensions!
karthur1
DRoam
I've wanted the ability to do this many, many times. I'd love to see this added.
Orest_iy
I really appreciate this idea since I build a lot of linked part in project. I have posted my own few days ago. I did not know you already published it. I really support the idea to kudos both to accumulate enough supporters in hope Autodes will do something.
brownst
Yes and Yes again!  Drag/drop the extension line(s) to other geometry works well and I miss that ability.
Benjamin
Is there any update on the status of this idea Autodesk? Extremely good, useful idea!
nhedler
It's been 9 years; has there been any official attention here?
jeffg28CLY
@nhedlerYup I've run into this myself several times as well.
Some geometry breaks, which means some reference dimensions also break, so they have to be moved. And by "moved" I mean "deleted, recreated, and then find and repair all formulas that used them.
Pro-E/Creo: Just right-click the dimension and select Redefine.
v2022.3 - Still can't do it, as far as I know.
Hunteil
I cross posted this idea into this combined idea: https://forums.autodesk.com/t5/inventor-ideas/sketch-dimension-improvements-redefine-dimension-arran...
I assume the developers would prefer to tackle all this at the same time.
wwang
Extremely important feature.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
