Ability to create subcategory in the Material Browser
Inventor 2014 allows the creation of a new category in the Material Library, unfortunately a sub-category cannot be created.  That functionality would help organize custom materials.
4 Comments
steve_lindley
Still the same in 2018. The Autodesk Material Library has a sub category under the metal category as standard, so why can't the users create their own?
We largely only work with steel, so our metal library is used most commonly. We name our materials typically by the grade (e.g. S275) and the British or European standard that defines the product, such as BS EN 10025. However, due to the large range of products and standards, we often find it difficult to locate exactly what we want. Also, usually we use terms such as box section, or flat, round, square, etc when discussing materials, so we need an efficient system that can combine all this. I believe sub-categories would allow us to do this.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
Lars_A1
I just ran into the same problem. Since there is no solution available, I opened a new idea:
Create subcategories in the Material Browser - Autodesk Community
