Hi All,
Many times when I want to manage a complex assembly using an iLogic Form, I would like to handle the parameters of the sub components directly from the form. Currently the only way is to create user parameters in the main assembly for all parameters in the sub components and then I can add this user parameters to the form. The first problem is the need of the lot of extra custom parameter and the second problem is to manage the changes of the user parameters I have to create a rule which always push the value of the user parameters from the assembly to the sub components.
Best regards,
Attila Farkas
