In a assembly you can create a mid plane by selecting two surfaces from two different components but can not create one with two faces from the same component. This brings you to either open the component and add the mid plane or create a offset plane distance 0 and then make the mid plane between the newly created plane and the other surface. Would really be a time saver to add this fonction.
