2D drawing same scale for all parts
For a 2D drawing, make it possible to set a scale for the entire drawing that has multiple unique parts (or make it linked to the primairy component scale).
Reason for this: we create cutting drawings, that needs to be exported to DWG format to cut it.
The DWG file will use the scaling of the primairy component.
If a secondary component is not set to the same scale, the DWG file will not contain the correct contour.
This is especially error prone, especcially if scaling needs to be changed after making a drawing with 10+ components.
