2D drawing dimension positioning to part
Make it possible to position dimensions, relative to part geometry. (sketch or relation to a point/ line)
This could be similar to how a section view line can be controlled trough editing the sketch, allowing it to be linked to part geometry.
Currently, dimensions are messed up often when changing part dimensions, or making a variant of a existing part/ drawing.
(clipping trough other dimensions, or clipping trough part).
Use case 1: a set of parts that has a similar shape, with edited dimensions (like a content center part), making drawings for each part trough replacing the referenced component.
Use case 2: editing a existing part, maintinging the same dimension spacing relative to part.
