2015 upgrade not off to a good start
Since upgrading to 2015 I have been disappointed with some simple things not working.<br><br>First, is sketch visibility. Normally while in a sketch you can turn on the visibility of another sketch. This no longer works in 2015. Once I end the sketch I'm in the other sketch turns on. Then I can go back into my sketch is use geometry from the other sketch.<br><br>Second is keyboard shortcuts. My shortcuts no longer work as expected. I use &quot;C&quot; for a circle in a sketch and &quot;C&quot; for constraint in assemblies. Now when I hit &quot;C&quot; in an assembly Inventor asks me to select a workplace to place the circle on.<br><br>Third is paste while in the constraint command. I used to use copy and paste while in the constrain command while placing bolts. It's just easier to place them when you need them and not place 20 at once. Now when I use &quot;ctrl v&quot; Inventor exits out on the constraint command.<br><br>Not sure why Autodesk would take features away, but please put them back.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
