>I have spent the last couple of years using SOLIDWORKS. INVENTOR is relatively new to me.
Read this one instead
http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf
JD
The SolidWorks sketch would be done the same as in Inventor. Usually covered in the first day of SWx training.
> If I edit Sketch3 and right click it is not showing me the degrees of freedom for some reason.
I forgot, you are using a much earlier release of Inventor. Did not exist in v11.
>If I donāt fully constrain the sketch will it have an effect on my stress analysis?
No, but I think there might be the same sort of basic FEA logic missing as was missing in first part sketch.
