Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Copying/arraying items
JWPepper
JWPepper
If anyone can assist in telling me the correct procedure in copying/arraying the nozzle stiffners (90 deg's) on the attached screen shot I would be most grateful - I can only create new sketches at the correct plane/position and re-sketch the geometry each time (labourious) there most be a way to copy rotate solids? the other method I tried was creating a rough outline for the stiff then press pull to correct thickness & use assemble to position flush........but nothing I do will making the floating plate shown on the screen shot move using assemble
schneik-adsk
Try selecting the 5 faces of the rib/stiffener and using radial array?
Or,
delete the current rib and recreate it as a separate body. Then array the body and then boolean it into the main form.
Kevin Schneider
JWPepper
Thanks, the first method I cannot select all the faces - namely the ones merged into the body only the outer faces
second works, I created new solid and in Boolean made new component which I never saw before.
Cheers
