Wrong Countersink Hole diameter in DXF-export...
serge
serge
When I do export to DXF, then the exported DXF is showing the upper/greatest diameter of de countersink-hole,
not the small diameter which is needed to drill.
How to avoid this?
Thank you for any ideas.
SMD
DEVIDTS Serge, CAD Consultant
http://www.CADdICT.be
mcgyvr
How to avoid this?
SMD
Is this a tapped hole?
You mention countersink but nothing about it being a tapped hole?
If it is a tapped hole then the response above applies..
serge
Thank you for these replies,
Unfortunatelly these are NOT tapped holes,
When I should use tapped holes (to simulate things), then my Holenotes are incorrect.
mcgyvr
don't use export face as thats just exporting the geometry on that face..
Right click on the flat pattern node and click "save copy as"
serge
Thank you!
