Writing iLogic Code For Patterns
ASchlaack
ASchlaack
I have a part I need to pattern but the number of times it is patterned is related to a length parameter...
If <= 60 in then don't pattern
If 60>X>=120 in then pattern twice
If 120>X>=180 in then pattern three times
If 180>X>=240 in then pattern four times
That's what I need to do using the rule... how would this rule be written?
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
ASchlaack
****ADDED****
The length on the part I'm patterning also needs to be controlled...
If <= 60 in then don't pattern AND length = X-6
If 60>X>=120 in then pattern twice AND length = X-9
If 120>X>=180 in then pattern three times AND length = X-12
If 180>X>=240 in then pattern four times AND length = X-15
Aaron Schlaack
MegaJerk
Does this code do it?
''' Things you'll need.
''' (3) parameters
''' --	Parameter Name -- Type   -- Unit ---------
''' -- someLength      -- Number -- in	 ---------
''' -- finalLength     -- Number -- in	 ---------
''' -- someQty	       -- Number -- ul	 ---------
''' Create the above parameters in your model.
''' The code below should do what you're after.
''' change the value of 'someLength' to see
''' the changes to your finalLength and Qty!
finalLength = someLength - 6.0
Select Case finalLength
	Case <=60
		someQty = 1
	Case > 60, <= 120
		someQty = 2
	Case > 120, <= 180
		someQty = 3
	Case > 180, <= 240 'So there is nothing after 240?
		someQty = 4
	Case Else
		someQty = 1 '??? Whatever value you want.
End Select
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
ASchlaack
I do believe this code wil work, however I didn't end up using it. I was able to write another that worked. Thank you.
If LENGTH <= 60 in Then
		GUARD_PATTERN = 1 ul
		Parameter("15-1-0000 - GUARD_HOLDER:1", "WIDTH") = LENGTH-6.5 in
If LENGTH > 60 And LENGTH <= 120 in Then
		GUARD_PATTERN = 2 ul
		Parameter("15-1-0000 - GUARD_HOLDER:1", "WIDTH") = (LENGTH-10 in)/2
If LENGTH > 120 And LENGTH <= 180 in Then
		GUARD_PATTERN = 3 ul
		Parameter("15-1-0000 - GUARD_HOLDER:1", "WIDTH") = (LENGTH-13.5 in)/3
If LENGTH > 180 And LENGTH <= 240 in Then
		GUARD_PATTERN = 4 ul
		Parameter("15-1-0000 - GUARD_HOLDER:1", "WIDTH") = (LENGTH-17 in)/4
Aaron Schlaack
