Ilogic loop to excell
Hi InventorWizardz,
I have a problem with the folowing script:
Ivolume = iProperties.Volume/1000 '(in cm^3)GoExcel.CellValue("3rd Party:Embedding 2", "Blad1", "A2") = Ivolume
Parameter("HoogteVolumePercent") = 1
i = 1
If Parameter("HoogteVolumePercent") < 100 Then
    While (Parameter("HoogteVolumePercent") < 100)
        GoExcel.CellValue("3rd Party:Embedding 2", "Blad1", "C"&i) = Ivolume
        i = i + 1
        If i = 100 Then
            Exit While
    End While
iLogicVb.UpdateWhenDone = True
The purpose is to export the value of Ivolume at a certain percentage to an embedded Excel. But the when running this rule every cell has the same value.
I think Ilogic is writing the value after the completion of the rule. But I can't figue it out to get it to work.
In Attachements you can find a screenshot and the part.
Hope someone can help
andrewiv
I modified your code to include an update before writing the mass to the "C" column and to also tell it to change the HoogteVolumePercent parameter to be the i value. This works for me
i = 1
		Parameter("HoogteVolumePercent") = i
		InventorVb.DocumentUpdate()
		i = i + 1
		If i = 100 Then
			Exit While
	End While
Andrew In’t Veld
Designer / CAD Administrator
Thanks Andrew !
Your solution works perfect !
