Working on projects on multiple computers
I want to know how to work a project from in class and at home. I sign into the same account on both computers, yet when I go home the projects I had been working on don't show up.
Mark.Lancaster
@Anonymous
Are you using Inventor or Fusion 360?  Based on your description it sounds like Fusion 360..
Inventor projects have nothing to do with the Autodesk Account you're using..
Mark Lancaster
mcgyvr
Try asking your "teacher" for help..
They "should" be able to provide you with the best workflow to accomplish the task..
johnsonshiue
Hi! Are you using Fusion Team to store your Inventor files? If yes, you will need to make sure you have access to the team hub. You can definitely store Inventor files in any cloud drive upload and download to your local drive.
Many thanks!
Software Test Engineer
