Working clock mechanism
Hi
Would anyone know if its possible to simulate a functioning pendulum clock with any of the auto desk software's. The clock design is of the galileo escapement type. I want to be able to have the pendulum moving as a result of the force from the force from the stored energy in the wound up weight and from the gravitational energy when turning directions. At the same time the weight which is held by a string would unwind itself.  Need to show this to a science class lesson. Thanks in advance
johnsonshiue
Hi! You may want to do a search for the term "Geneva" on the forum or Autodesk Knowledge Network. There have been quite a few past discussion about the topic. Please take a look the following thread as an example.
https://forums.autodesk.com/t5/inventor-forum/simulation-for-geneva-cam-assembly-inventor-2016/m-p/6...
Many thanks!
Software Test Engineer
JDMather
Environments>Dynamic Simulation
