Workflow to create a .FBX File
I have created a Square Shaft in the most simple of forms, can someone assist me or direct to on how I can output this 3D Model in Inventor to a .fbx file?
Thank you in advance for your assistance!
mdavis22569
from Inventor ...I don't see it's possible.
however:
3DS Max can directly import the Inventor assembly file, then export it to FBX
http://www.autodesk.com/products/fbx/overview
Mike Davis
Unfortunately I do not have a 3DS Max, and unfortunately cannot afford it at the moment.
Anything other methods of converting the Inventor Assembly File?
Thank you,
DJ
admaiora
You can try upload your model in A360 , then download it as fbx.
Pretty sure you can do it
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
vladimir_michl
E.g. through AutoCAD, Max or Fusion 360 - see what the conversion assistant advises:
http://www.cadforum.cz/cadforum_en/formats.asp?fmtin=5&fmtout=10
Vladimir Michl, www.cadstudio.cz
Admaiora,
Can you give me a little more in depth Step by Step on how to this if you have accomplished it?
Thank you!
DJ
admaiora
You can download Fusion360. (You can use it for free for 1 year!)
You have to create an Autodesk account (if you haven't it already)
Then
Admaiora
