Work/reference point at the intersection of a 2d sketch entity passing through a plane
staff7NWEE
staff7NWEE
I am trying to create a workpoint or reference point where a line from one sketch passes through a work plane.  For instance If I sketch a spline on the XZ plane that I would like to use as a coincident point for a profile, and then create an offset plane from the YZ plane a distance away so that I can create a lofting profile between the first and last profile in the lofting chain, but want to be sure the intermediate profile is coincident with the rails that pass through it.
For a better example, in fusion360 I can select the intersect command and select 2d sketch entities from non parallel planes and it will create work points where the entity passes through the current work plane (if it does).  I can then draw on the current workplane and attach my geometries to the work points that were created by the intersecting lines so that I may loft multiple planes together and be certain that the rails and profiles are coincident through out.
CCarreiras
Hi
  1. Create new work point
  2. select the spline
  3. select the plane
    You will get the intersection point between spline and plane
CCarreiras
andrewiv
I'm not sure if I fully understand what you are trying to do but if you want to create a work point that is at the intersection of a plane and a sketched line all you have to do is click on Point in the Work Features panel and then select the line and the plane.
Andrew In’t Veld
Designer / CAD Administrator
staff7NWEE
That did it, thanks guys.
