Work planes ain't appearing
Dracoholikus
Message 1 of 8
Dracoholikus
Hello, i am having some troubles after updating to Inventor 2018.
When i open any part in an assembly(Expand), while constraining, and go to the planes of the part
i can move my cursor over the planes and it won't show me what plane it is.
To fix this i need to move my cursor to the screen and then return to the plane and it will appear,
after this the problem stops, if i collapse the part and then expand again sometime to constrain the plane
it will happen again, BUT if i leave the part expanded the problem disappears.
This really annoys me in large assemblys.
Is there a solution? It seems like a loading and unloading of resources.
See attached image as ref.
Replies (7)
Message 2 of 8
Mark.Lancaster
@Dracoholikus
A static image really doesn't show the true problem.  Smiley Very Happy   Perhaps you want to create an Autodesk Sceencast and walk us through the workflow.
Have you applied all the latest Inventor 2018 updates that you are entitled to?
Have you upgraded your graphics card?  Don't rely on Windows telling you its up to date.  Go to Windows Device manager, expand display adapter, right mouse click on your card and select properties.  Go to the driver tab and see what the date of your graphics card driver is.  It is not at least a 2017 driver date it may be time for a driver update.  Also while in Inventor (while a file is open), go to Tools/Application Options/Hardware tab and select the diagnostic button.  Is Inventor 2018 using the correct video card?  Also on that tab, what is your settings?
Mark Lancaster
Message 3 of 8
Dracoholikus
I've never used screencast but will try.
About the tab:
This Direct3D graphics driver is Microsoft WHQL certified
Graphics Hardware Description:
Advanced Micro Devices, Inc. AMD Radeon Graphics Processor (0x1313)
AIRViz Device Manager \ VirtualDeviceDx11
Feature Level 5_0
Performance Mode
Hardware Renderer
OGSScene.dll
Graphics driver file aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll is version 22.19.662.4
The display is using 32-bit color
Inventor Version:
Build: 112, Release: 2018 - Date: Thu 02/16/2017
64-Bit Edition - 8192.00 GB
Loaded Inventor Add-Ins:
Assembly Bonus Tools
Simulation: Dynamic Simulation
Simulation: Frame Analysis
iCopy
System Information:
Operating System: 		64-bit Microsoft Windows 7 Ultimate  (Build 7601) Service Pack 1
Language: 			Portuguese
System Manufacturer: 		MSI
System Model: 			MS-7721
BIOS: 				BIOS Date: 12/11/14 16:29:37 Ver: V9.20
Processor: 			AMD A8-7600 Radeon R7, 10 Compute Cores 4C+6G   (1 processor, 2 physical cores, 4 logical cores)
System Memory: 			6,944 GB RAM
Graphics Device Information:
Renderer: 			HAL
Manufacturer: 			Advanced Micro Devices, Inc.
Chip Type: 			AMD Radeon Graphics Processor (0x1313)
DAC Type: 			Internal DAC(400MHz)
Graphics HW Memory: 		989 MB
Display Mode: 			1920 x 1080 (32 bit) (60 Hz)
Graphics driver file: 		aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver file version: 		22.19.662.4
Driver Date: 			20 July 2017 0:00:00 UTC (Coordinated Universal Time)
Direct3D Graphics Device Information:
Adapter Description: 		AMD Radeon(TM) R7 Graphics
Vendor ID string: 		0x00001002
Device ID string: 		0x00001313
VendorID: 			1002
DeviceID: 			1313
SubSystemID: 			77211462
Revision: 			0
Direct3D 10 / DXGI System Information:
Dedicated Video Memory: 	989 MB
Dedicated System Memory: 	0 MB
Shared System Memory: 		3,222 GB
DxDiag System Information:
Operating System: 		Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_ldr.170810-1615)
Language: 			Portuguese (Regional Setting: Portuguese)
Processor: 			AMD A8-7600 Radeon R7, 10 Compute Cores 4C+6G   (4 CPUs), ~3.1GHz
System Memory: 			8192MB RAM
Page File: 			7561MB used, 6658MB available
DirectX Version: 		DirectX 11
DxDiag Version: 		6.01.7601.17514
DxDiag Graphics Device Information:
DirectX Version: 		10.0
DDI Version: 			11
DDI Version Number: 		b
DxDiag WHQL Level: 		0
Driver Signed Valid: 		True
Driver Signed: 			True
Revision:
Graphics HW Memory: 		192 MB
Display Mode: 			1920 x 1080 (32 bit) (60Hz)
Driver file version: 		22.19.0662.0004
Driver Date: 			7/20/2017 20:39:20
WHQL Level: 			1
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
Graphics driver log information:
About the Inventor updates i am not really sure. Inventor is using the correct card.
I'll see what i can do about the screencast.
Message 4 of 8
Mark.Lancaster
@Dracoholikus
You are at Build 112 which is the original release of Inventor 2018..  Inventor 2018.1 is out and there's a update to that as well.  Your graphics driver looks ok..  Not sure if you are on a active maintenance plan or subscription but if you are, you can install Inventor 2018.1 and get new features (and it may fix graphically issues you may be experiencing).
What's new in Inventor 2018.1
Mark Lancaster
Message 5 of 8
johnsonshiue
Hi! I think you are talking about Pre-Highlighting. I don't recall the default setting now. Your settings might be off. Please go to Tools -> Colors -> check "Enable Pre-Highlighting" and "Enable Enhanced Pre-Highlighting" options.
Many thanks!
Software Test Engineer
Message 6 of 8
Dracoholikus
Sorry for the delay, Enabling "Prehighlight" didn't do the job 😕
For the screencast, i am very busy at the moment but soon i'll get this done.
About the update, also will do.
Message 7 of 8
johnsonshiue
Hi! Another thing to try is change your Selection Filter at the top. In assembly, the default is set to Component or Part. In order to select a workplane, the selection filter will need to be set to Select Features or Select Faces or Edges. Does it work now?
Many thanks!
Message 8 of 8
This is the one that worked for me thanks, for the last month I've been hovering over the plane in the browser then having to give the assembly a nudge to highlight the corresponding plane in the part.
