hi this wont extrude, im trying to make a skeleton for a frame but it wont extrude, please help
Solved by BeKirra. Go to Solution.
@fillipluigiferra wrote:hi this wont extrude, im trying to make a skeleton for a frame but it wont extrude, please help
Please try this.
Otherwise, extruding solid in assembly (IAM) is not possible (wont extrude as you mentioned), except cutting off solid(s) in assembly.
HTH
Please try this.
HTH
You cant send just the assembly, we need ALL components that also go with that assembly.
