Add fasteners as an option to the Tube & Pipe styles when a style is set to flanged. Allow the user to set, as a rule, what type of bolts, studs, washers, nuts etc, are allowed on a particular pipe style, and then whenever a flanged fitting is placed, automatically create the bolted connection for that item, based on the specifics set up in the rule.
It's just a thought.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Use the form below ..., and any improvements you would like to see.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Thanks JD. I was going to head that way eventually. I was kind of hoping to see what people in here thought of the idea. Good, bad,... ugly...
Chris Benner
