Inventor Forum
Wiring
5 REPLIES 5
211 Views, 5 Replies
Wiring
Is there a way to make a wire harness follow a moveable part. For example, i am wiring from terminal block to a door, but when i close the door, the bundle does not move with the door.
5 REPLIES 5
Yes. Check out Adaptivity
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP2, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://teknigroup.com
Also, helps if you provide the version you are using....
260-399-6615
mcgyvr
It won't dynamically move. I believe you have to hit the update button once its in the secondary position.
It will if you do a drive constraint.
260-399-6615
Here's a 2008 version. If you have Dynamic Simulation, apply Gravity to the
link points.
Keep in mind that the wire will dissappear if it self-intersects.
The linkage provides a limit on the length, and allows the wire to flex.
Just select DriveThis! and enjoy.
260-399-6615
