Hello Inventor Forum Members,
This is the first time posting a question on this forum, so hope it works.
I've designed a box with a wiring harness, but somehow the harness got all screwed up. The image below shows the screwed up wiring harness, with visibility turned OFF to most parts and sub-assemblies. I think that the whole assembly got moved (my fault somehow), but the wiring didn't move with it. The wires are still connected to the pins, but the "points" along the route moved, and now it looks like this. Does anyone know how I can get all the wires and segments back into the correct position - without re-routing each one? That would be very time consuming, and I've really come to dislike messing with wiring harnesses in Inventor. In my opinion, it is cumbersome and could be improved a lot.
![4 Assembly Wiring - Screenshot.jpg 4 Assembly Wiring - Screenshot.jpg](https://forums.autodesk.com/t5/image/serverpage/image-id/1103589i536081DB9193C7C5/image-size/large?v=v2&px=999)
Thank you in advance for any help you can provide.
Bill
