I am having issues with the wireframe randomly disappearing when visual style "Shaded with Edges" is selected. If I change the style to "Shaded" and then back to "Shaded with Edges" everything displays well for a minute or so and then the wireframe disappears again. As you can see in the picture only random solids in the design seems to be affected. Sometimes zooming in and out also makes lines appear and then disappears again. Anyone have any ideas what could be causing this issue?
General Info:
Autodesk Design Suite Ultimate 2017 R2
Windows 10
CPU: Intel i7-4790
Video Card: Quadro K4200
Video Card Driver: 368.39
Sounds like a video driver issue. I would start there.. Don't rely on Windows telling you its up to date, check the mfg web site. For Inventor 2017 on WIndows 10, you should have at least driver version 10.18.13.5456 for your k4200 card...
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi mattBA,
It's a known issue with 2017:
See this link for a setting workaround:
I hope this helps.
Curtis
