wireforms
wireforms
Message 1 of 14
wireforms
Any easy way to change a thrid party's .stp files radii without remodeling the whole file/part?
Replies (13)
Message 2 of 14
CCarreiras
Yes, using "recognize features" app.
Let me try...
CCarreiras
Message 3 of 14
I've tried to use that before with "disasterus" results. If it works
great.
Nick
Message 4 of 14
JDMather
...or
Delete Face with Heal option and then place your own Fillets.
...oops, I didn't open the file.
Message 5 of 14
mflayler
Are you talking about adjusting the part's overall diameter of this 3D pipe or a certain bend along it's path?
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 6 of 14
No the diameter is correct. I need the bend radii on the corners to be 8mm
ctr not 12mm
Nick
Message 7 of 14
CCarreiras
WOOOW...   with this part, you have to repair mannually... but it can be donne easily, but with some work...
Want an example?
CCarreiras
Message 8 of 14
yes I would any help would be greatly appreciated
Nick
Message 9 of 14
mflayler
This should be redrawn then.  I know its not the best choice, but it will give you the shape you need without an overly heavy modification.
If you wanted to just change the overall diameter, this is how you do it.
Message 10 of 14
JDMather
Nick
What version of Inventor are you using?
Maybe something like this (see attached)?
Message 11 of 14
Message 12 of 14
CCarreiras
Hi!
I prefer JD method, but if you are not confortable with 3D sketch, you can do it with 2d Sketches, but will give you more time to solve.
CCarreiras
Message 13 of 14
JDMather
How did you do that? The model looks good.
Message 14 of 14
JDMather
Turn on your sound -
About 7 yrs ago I wrote a paper on generating part of the tooling for something like this - but the process is kind of advanced and the software has changed since then. I might be able to dig it up if needed. You would have to interpret the workflow for r2016.
