wire form
wire form
wire form
Hello everybody,
I'm trying to form wire as the shape in the attached file but no success even I've tried spline tool.
Is there any solution?
atajabbas
inventor 2016
JDMather
Well, I made a mistake on my first attempt, but the attached should give you an idea.
Well Mr. Mather it is a very nice solution and it gives me a good skills.
Thankyou
atajabbas
Inventor 2016 user
Hi JD Mather,
Well, I have tried to follow what you did in the 3D sketch mod, but I couldn't> Also Itried to follow your step to form the spring end in the attached ipt to apply some fillet and eliminate the sharp corner. Would you please tell me how?
atajabbas
JDMather
Maybe something like this is what you are after. (see attached file)
JDMather
I might have to come up with a better solution - that one is not fully parametric.
Thank you so much for your reply.
May be I seem boring, but, with my apologize, I followed your steps to do it but no success. Indeed I do not know how to use the "Intersection" tool, where , how, why and when?
The attached file is my attempt to follow your steps. Would you please tell me where is my mistake. This will make me understand how to use the tool
Thank you a lot,
atajabbas
