I see a need for a Window Selection in a couple of different applications that would be very useful:
1) When in a Sketch, I want to select the Equal (=) constraint to match the diameter of one circle to the 300 other circles I have in a perforated plate. Currently, I need to selected them one-by-one, essentially clicking the same circle twice to carry the diameter to the next circle. If I could select the first circle as the source, and window around all the rest, I just saved a crucial amount of time. This same scenario actually works when using Copy or Move.
2) When in Frame Generator, I want to select 'Remove End Treatments' and then window-select a number of structural members. Currently I have to select each one.
Solved by andrewiv. Go to Solution.
In the sketch, if you window select all your circles first and then click on the equal constraint it will apply the constraint to all of them.
Andrew In’t Veld
Designer
