I am bumping this thread to see if progress has been made on the angle constraint issue.
This problem has been around for a long time and I'm wondering if there are any additional tips or video tutorials that could shed some light on the matter.
I've been using IV since around 2002 and every now and then I do design where angle constraints just drive me crazy, like now.
I've tried the tip suggested by Bmiller63 but the results are unpredictable, i.e.. works sometimes and not others. Strange.
You should see some improvement in 2014 in this area.
Thanks for the response Blair. What do you know, is Autodesk aware of the issues and working on something?
Hi folks, the jumping like a loop angle in animation is still here, even if u use only positive values 🙂 8 years is not enough for Inventor to solve such a trivial problem. I'm using Inventor 2018 and directed angle still doing random.
Any idea how to make them (inventor programmers) work for our licence money?
@Anonymous Can you post files that show the problem you are having? Have you tried to use the explicit vector option that was put in place to address issues with the angle constraint..
There is no "bang for the buck" in fixing old issues for Autodesk.. But we as users might be able to help you find a workaround to your issue or show you how the problem should be solved.. or at the very least express our condolences and poke at Autodesk with you....
Having a real model that clearly shows the issue is the best way to communicate these issues and make forward progress...
@Anonymous,
Hi! Please share an example exhibiting the behavior. I suspect it would work better if the explicit vector angular constraint was used.
Just to clarify what Brian said, it is not true that Inventor team ignores old defects. We do try fixing defects regardless of their ages. When it comes to fixing, every defect has gone through thorough review process for its risk and feasibility. Most of the time, the unfixed defects are due to significant technical risk involved. Fixing it could make the matter worse. It sounds counter-intuitive but it is true.
Many thanks!
