Why it is not updating?
I thought I had adaptive assembly, until I changed length of vertical I-beam.
Could someone explain why it is not updating? In particular holes for this transverse beam connection are not updated (you can see that). Also there is not massage warning abut lost reference for sketch projection, but obviously there is nothing that would be projected in to position projection is now.
Cris.
fakeru
Turn the adaptivity on for the subassembly that contains this I-beam.
Autodesk Inventor 2015 Certified Professional
I cannot do that. It is greyd.
Cris
fakeru
Most likely the i-beam is used in another assembly as adaptive and that's why you can't make this subassembly adaptive. Try to find if that is the case and see where you need it the most to be adaptive. Or make a copy of this i-beam.
