Why is punch tools so manual and hostile towards beginners?
MatsNorway1
Message 1 of 12
MatsNorway1
So i select the face and i put down a centermark.  Then i select the punch tool button and get this menu.
Allright cool you might think, it got a few defaults within default folder or something, but none is seen in menu so you click browse, and tada.. you end up in a random folder.. with no punch tool presets.
And i have tried to make punch tools before, its horrible.
So if you got a chunk of punch tool defaults lying around and do not mind sharing them i would love to get going. As i get familiar with punch tools i will hopefully learn over time how they are built.
If you want spesifics i am just trying to punch down a face for a rivnut so a component can go past and the rivnut can be within that sliding face.
‌:nauseated_face: ‌:face_with_medical_mask: Fusion 360
Replies (11)
Message 2 of 12
CCarreiras
Hi!
The punches are in a default folder.
Probably you use one punch from another folder and this location stood in memory.
The default location is:
C:\Users\Public\Documents\Autodesk\Inventor 2023\Catalog\Punches\
If you need a punch, design the geometry in a part and share it here. we try to help to turn the geometry into a punch.
CCarreiras
Message 3 of 12
CGBenner
@MatsNorway1
Check under Application Options\iFeature\Punch Tools. Can you share a picture of what is in this path?
Chris Benner
Message 4 of 12
Frederick_Law
So you need a hole and emboss.
Model that and you can make it iFeature or Punch.
Message 5 of 12
MatsNorway1
Message 6 of 12
Frederick_Law
Did you copy the files in the original iFeature\Punches folder?
Message 7 of 12
MatsNorway1
No, as pr installation not including Vault setup.
Message 8 of 12
Frederick_Law
Well, with no files in there and you expect to find something in an empty folder? 🙄
The folder setup in your IV is not default installation location.
User or Admin need to copy the correct files there.
Message 9 of 12
MatsNorway1
I have not tried to use punch tools in months perhaps a year. If its that hostile towards its users its not good.
I am the user, i have admin rights. I can/could fix this with a tutorial that makes sense. If i get the time.
Summary: Punch tool is bad, and everyone hates Fusion 360 for mechanical design
Message 10 of 12
JDMather
@MatsNorway1
How much training have you had in using these tools?
Message 11 of 12
MatsNorway1
Inventor>Fusion 360 (according to seemingly every user that has done work or done studies using both)
Message 12 of 12
Frederick_Law
Hmmm, you need tutorial to copy files from one folder to another? 🤔
Someone (user or admin) set a new folder location for the Punch (iFeature) and did not copy the required files.
Of course you can create new punches.
I made a few already.
Also some SAE ports.
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-1A5F9CD1-80A8-4462-894A-4D8C9DFCDB51
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-C2D08AAD-D86D-4720-96E4-8E0DA7374BE9
