"Albert Allen" <I
href="mailto:albert@sno-cat.com">albert@sno-cat.com> wrote in message
href="news:9569CF38CE3282DC1BF3273161264E31@in.WebX.maYIadrTaRb">news:9569CF38CE3282DC1BF32731612......
have been using this part for quite a while now with no problems and all
of
the sudden if I try to edit any sketch all of the features below it
fail!
I have posted it to the CF under the subject Cast housing half
and wondered
if anyone could take a look and tell me what happened. Just go
to a feature
and edit the sketch then edit a dimension (don't even change
the value) then
exit the sketch and you will see everything else fail below
it. I can't even
move the EOP because the part will fail when you move it
back down.
HELP! C'mon Adesk I have been on your side on this version
but a part just
up and failing for no reason really scares
me.
"RuiF" <rui.cad@netcabo.pt>
wrote in message
href="news:EFC37453BA7D5008194756F0FAAF4D9D@in.WebX.maYIadrTaRb">news:EFC37453BA7D5008194756F0FAA......
Do a REBUILD ALL and your part fails on the
second extrusion.
Needs some serious looking at.
Rui
"Albert Allen" <I
href="news:9569CF38CE3282DC1BF3273161264E31@in.WebX.maYIadrTaRb">news:9569CF38CE3282DC1BF327316......
all
of the sudden if I try to edit any sketch all of the features below
it fail!
half and wondered
Just go to a feature
even change the value) then
else fail below it. I can't even
when you move it back down.
side on this version but a part just
scares me.
"Albert Allen" <
href="news:030577EF41A587F74F14D05B8AA83DE0@in.WebX.maYIadrTaRb">news:030577EF41A587F74F14D05B8AA......
I just looked at an older copy of this part
and it does not fail! but the newer part has not changed at all from the
older one! This part is derived into two machined parts and they have changed
a little over time and my old copy of the original part has not seen these
changes to the derives.
I will post the data set for the non failing part
to the CF as well.
I REALLY NEED YOU TO LOOK AT THIS
AUTODESK!
I have provided you with before and after data
sets (you always ask for them) of a real world failure so PLEASE take a
look. I am scared to do any other work until I find out why this
happened!
"RuiF" <
href="mailto:rui.cad@netcabo.pt">rui.cad@netcabo.pt> wrote in message
href="news:EFC37453BA7D5008194756F0FAAF4D9D@in.WebX.maYIadrTaRb">news:EFC37453BA7D5008194756F0F......
second extrusion.
Rui
"Albert Allen" <I
message
href="news:9569CF38CE3282DC1BF3273161264E31@in.WebX.maYIadrTaRb">news:9569CF38CE3282DC1BF3273......
all
it fail!
half and wondered
happened. Just go to a feature
dimension (don't even change the value) then
will see everything else fail below it. I can't even
move the EOP
because the part will fail when you move it back down.
HELP! C'mon
Adesk I have been on your side on this version but a part just
up and
me.
"Patrick Berry" <
href="mailto:xpatrickx.xberryx@xax-xdecx.com">xpatrickx.xberryx@xax-xdecx.com>
wrote in message
href="news:88EE3CCEA0E3122CF69BFAF392BDD7ED@in.WebX.maYIadrTaRb">news:88EE3CCEA0E3122CF69BFAF392B......
I've had that happen twice on different
parts. Both were fairly large and complex and both required a huge
amount of rebuilding afterwards (read: much time and money). In
both cases a simple feature near the top of the tree suddenly failed.
All features below which are effected by this feature where knocked out.
Since then I run rebuild all every few features and save a backup copy after
each successful rebuild. I haven't had a problem since
then.
Pat
"Albert Allen" <
href="news:030577EF41A587F74F14D05B8AA83DE0@in.WebX.maYIadrTaRb">news:030577EF41A587F74F14D05B8......
part and it does not fail! but the newer part has not changed at all
from the older one! This part is derived into two machined parts and they
have changed a little over time and my old copy of the original part has not
seen these changes to the derives.
part to the CF as well.
AUTODESK!
happened!
"RuiF" <
message
href="news:EFC37453BA7D5008194756F0FAAF4D9D@in.WebX.maYIadrTaRb">news:EFC37453BA7D5008194756F......
second extrusion.
Rui
"Albert Allen" <I
message
href="news:9569CF38CE3282DC1BF3273161264E31@in.WebX.maYIadrTaRb">news:9569CF38CE3282DC1BF32......
all
below it fail!
housing half and wondered
what happened. Just go to a feature
move the EOP
HELP!
C'mon Adesk I have been on your side on this version but a part
just
me.
"Lester Martin" <
href="mailto:lester@reist.on.ca">lester@reist.on.ca> wrote in message
href="news:24DCA302632AE063C4969D368B51374A@in.WebX.maYIadrTaRb">news:24DCA302632AE063C4969D368B5......
Has Happened to me.
What I did was opened it in Inventor 6, saved it,
then opened in Inventor 7.
Don't ask me why it worked. I had used it
in 7 before.
size=2>
"Albert Allen" <
href="news:7BECF2E6DC8A218AB4192C959C69F907@in.WebX.maYIadrTaRb">news:7BECF2E6DC8A218AB4192C959C6......
I don't want to be obnoxious but TELL ME YOU ARE
WORKING ON THIS AUTODESK! PLEASE!
You could not get a better data set and data
set's are what you always want. I have a lot, a LOT of time into this project
and as others have said having a model do this is not
acceptable or affordable!
"Lester Martin" <
href="news:24DCA302632AE063C4969D368B51374A@in.WebX.maYIadrTaRb">news:24DCA302632AE063C4969D368......
Has Happened to me.
it, then opened in Inventor 7.
in 7 before.
size=2>
"Albert Allen" <
"Lester Martin" <
Has Happened to me.
in 7 before.
size=2>
"Glenn Chun (Autodesk)" <
href="mailto:glenn.chun@autodesk.com">glenn.chun@autodesk.com> wrote in
message
href="news:33522B7D53FBFC6E8C76CEC6001900A1@in.WebX.maYIadrTaRb">news:33522B7D53FBFC6E8C76CEC6001......
Albert,
I logged a defect against this (Internal tracking
# 523528).
Glenn Chun
Autodesk Inventor Development
"Albert Allen" <
href="news:7BECF2E6DC8A218AB4192C959C69F907@in.WebX.maYIadrTaRb">news:7BECF2E6DC8A218AB4192C959......
ARE WORKING ON THIS AUTODESK! PLEASE!
project and as others have said having a model do this is not
"Lester Martin" <
message
href="news:24DCA302632AE063C4969D368B51374A@in.WebX.maYIadrTaRb">news:24DCA302632AE063C4969D3......
Has Happened to me.
in 7 before.
size=2>
