Why don't the drawing dimension update automatically?
When in drawing, I have "Retrived Dimention". Then I mark a dimension and right-click to select "Edit model dimension" and enter a new value.
The model and the drawing changes accordingly, but the existing dimention, which was edited, do not. Also, when adding a new dimension on the same "item" it show the correct value. So I have a hole the are both Ø10 and Ø50 at the same time.
In Document setting I have checked for Defer Updates
Why don't the dimension update automatically?
Xun.Zhang
Please uncheck defer update to get the model up to date.
Hope it helps!
Xun
Thanks. I see now that there is an not-updated symbol next to the drawing, as shown. But I do not get the Defer Updates option when I right-click it ?
johnsonshiue
Hi! Defer Update only applies to entire drawing file, not individual drawing view.
Many thanks!
Software Test Engineer
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Are you saying that the retrieved dimension that you just edited doesn't change but the model updates correctly?
When I bring in a part > Retrieve Model Annotations... > Select the wanted dimensions > Edit Model Dimension... > it updates the part and the dimension accordingly.
Is there a reason you are wanting to use Defer Updates?
If you can record a screencast or attach your files that would be helpful in understanding what you are experiencing.
Please select the Accept as Solution button if a post solves your issue or answers your question.
