Inventor Forum
Why cant I place a radial dimension on the IDW view?
2 REPLIES 2
WILLIAMF
231 Views, 2 Replies
Or measure the radius on the model? Maybe because of the way the part was modeled. Can someone help out?
I will need to dimension this bent tube in the near future.
Dell Precision 5820
Windows 10Pro
Quad Core Intel Xeon
32 Gb SDRam
NVIDIA Quadro
Product Design Suite 2019 Ultimate
2 REPLIES 2
JDMather
in reply to: WILLIAMF
Will Include of the 3D path sketch (or the 2D sketches used to make the path) work for your needs?
WILLIAMF
in reply to: JDMather
Yes, I guess, and I had done that. We normally dimension inside of bend. But it'll work. The tube bender will need to do the arithmetic, or I can use a leader.
As far as dimensioning the intersection points I was able to use axis at intersection points as a snap point for my dimensions and used the 3D sketch to dimension the angles.
The only dimension I can't place is for the tangent points of the bends, but I think with some work planes axis and points I will get what I need.
Thanks again JD, and thanks for the lesson a couple of weeks ago on intersection of 2  (2D) lines to create 3D sketch....
Dell Precision 5820
Windows 10Pro
32 Gb SDRam
NVIDIA Quadro
