Why cant I modify this?
ryanTPVFU
ryanTPVFU
This was created from someone else. I need to modify a section of the frame. The "edit with frame generator" is not an option.
Inventor 2022
Thank you
mcgyvr
You need to include all ipt files too. An iam just links to the part files used in it and does not include them in itself.
Or are you trying to edit "Middle Tubes"? If so you need to open that iam file by itself and edit it from there.
ryanTPVFU
Please see attached pack and go
ryanTPVFU
I figured it out! You have to right click, edit the WHOLE frame assembly, then you can right click on the individual frame pieces and edit with frame generator!
