White Sheet
White Sheet
vmontefusco
White Sheet
vmontefusco
Regarding Sheets: I want the background to be white. How is this accomplished?
Vince
swalton
See if the options in the color scheme editor do what you need.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2023/ENU/Inve...
Steve Walton
Inventor 2025
Vault Professional 2025
vmontefusco
I want to change the background of the sheet color from what it is to white. See attached.
Thank you
Vince
almuhandiswep
Look at this picture:
pcrawley
If you want to permanently change the colour, you'll need to change it in your drawing template:
  1. Create a new drawing
  2. Tools > Document Settings > Sheet
  3. Set the sheet background colour to white
  4. Close Document Settings
  5. File > Save Copy As Template
  6. Overwrite the existing Drawing template (or save it as something new if you want both options).
Peter
vmontefusco
THANK YOU!!
Vince Montefusco
www.imdb.com
