White circle 'i' symbol with no prompt to tell you what is wrong with i-part
Inventor 2017. I'm doing a lot with i-parts and i-assemblies. One thing that has cropped up is that next to an i-part table icon in the browser of an i-assembly, a white circle with an 'i' appeared indicating an error. However, hovering over the icon gives no indication as to what the problem is. Going into the i-part gives no clue either. Tried replacing the component and tried regenerating the i-part with the error - no joy. To get rid of it I did this: close the top level assembly with the error. Delete all of the i-part member files (indicated by the icon) from the folder where they reside. Open the assembly - it will report the missing link to the i-part. Point Inventor to load the i-part factory file. Once that's loaded, in the assembly browser, go to the assembly table and regenerate all of the assembly members. At the same time, the lower level i-parts called by the i-assembly table will be generated in sync with the newly regenerated i-assembly members. I think that is what the root of this annoying error is - I must have changed either the i-assembly or i-part and because they are linked by the i-assembly table they are out of sync if you do this. If there is an easier way to clear this error I would be glad to know.
