Which on of these can i uninstall?
Message 1 of 8
Hello, which one of these can i uninstall without damaging inventor?
My hard-drive is very small and has run out of space so i am looking to delete unnecessary parts of inventor(which wouldn't in stall on 😧 drive for some reason).
sergio.bertino has embedded your image for clarity.
Replies (7)
Message 2 of 8
CCarreiras
Hi!
You can uninstall DWG True View.
Inventor uses Dwg True views to visualize/Preview Autocad Docs in several operations import/export, therefore, you can unistall it from C: drive, but install it in another drive you got.
CCarreiras
Message 3 of 8
TheCADWhisperer
Do you have these files on your drive?
Do you have these folders on your drive?
Message 4 of 8
mcgyvr
We can't answer without knowing everything you do with Inventor..
They are all needed for some aspects of Inventor...
Hard drives are CHEAP.. Go buy another one..
Message 5 of 8
Mark.Lancaster
@Anonymous
If you're running out of disk space,  please review Travis' KB article for more information
Update:  Bad link..  Use this instead https://forums.autodesk.com/t5/installation-licensing/out-of-disk-space-during-installation-to-anoth...
Mark Lancaster
Message 6 of 8
johnsonshiue
Hi! Like Carlos mentioned, you can uninstall DWG True View since Inventor does not depend on it in any workflow. You may consider clean up %temp%. Also there might be less frequently used applications on the hard drive. Those should be uninstalled first.
Many thanks!
Software Test Engineer
Message 7 of 8
where can i find those?
Message 8 of 8
JDMather
You might not have them, especially the first three.
If you don’t know how to search your  disk - do you have a friend with more experience to help you out?
You might need to place * in place of the term English in the search.
