Where is the file that stores text presets? - Inventor 2026
Hi Everyone,
Helping set up a new guy at work, and I've got a pile of preset text for some of our common assemblies that we work on so we can select them and have the same note populate through our drawings.
I found a way to copy the common presets to a common folder on the drive and then changed the application options folders to point towards a common preset folder. I had looked at the help section (https://help.autodesk.com/view/INVNTOR/2026/ENU/?guid=GUID-0FDF0162-5374-4FC8-B6E3-59FDBC9AAA40) for working with presets and it got me close but not quite where I wanted to be.
When I navigate to the appdata/roaming/autodesk/inventor 2026/presets folder I have 5 files. CoilCmd, DrawingWeldSymbolCmd, EndFillCommand, HoleCmd, ThreadCmd. Those are all the files in the folder.
These make sense based on the files where I have presets that are used within inventor, however I can't seem to track down where the text presets are. After I've set up my local copy of inventor to point to the common folder that we are planning to use, I had lost my list of text presets.
Long story shorter, what file does this save into and how can I find it? Any help would be appreciated.
@Scottyos Your post title was modified to add the product name and version and to increase findability - CGBenner
