Where is my Rectangular Pattern
vmontefusco
Message 1 of 8
vmontefusco
Greetings
This is such a basic question that I'm embarrassed to ask, but my mind won't direct me to the answer. I created a, IPT part, then did a rectangular pattern. I made a change to the sketch and now I have to change the pattern and I can't find the pattern no matter how hard I try R clicking the sketch or extrusion.
Vince
Replies (7)
Message 2 of 8
salariua
Was the pattern in the sketch?
If so then you can right click sketch elements (part of the pattern) and choose Edit Pattern.
Let us know how that goes.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 3 of 8
vmontefusco
Adrian
I created a simple pattern in Sketch mode and I don't know why, but I can't find what you are saying. If you have time, please see the attached IPT.
Thank you
Vince
Message 4 of 8
Mark.Lancaster
@vmontefusco
While editing the sketch, if right mouse click on something and select Edit Pattern..
But I would strongly suggest that you use feature pattern over sketch pattern..  Make one by a sketch and then pattern using
Mark Lancaster
Message 5 of 8
salariua
@vmontefusco
I only have access to 2017 here but I will look at it later on, unless someone else manages to open your 2018 file.
A quick way to edit sketch patterns is by showing all constraints and then you can right click pattern constraint or one of the sketch elements and choose Edit Pattern like this:
Adrian S.
blog.ads-sol.com
Message 6 of 8
vmontefusco
Thank you for your simple solution. I normally pattern the feature way, but I was experimenting.
Vince
EFX Film & TV
Message 7 of 8
vmontefusco
Thank you for assisting!!!
Vince
Message 8 of 8
salariua
Our pleasure to help you, glad your problem is solved,
Adrian S.
blog.ads-sol.com
