Where does Frame Generator pull the data from in the Size drop down menu
Shag_Bore
Shag_Bore
-Created an profile
-Made it an iPart
-Authored the part as a structural member, then published it.
I thought the Size drop down menu in the frame generator dialog box pulled it's information from the "Designation" column in the Family Table, so I manually added all that information to the iPart.
When proceeding to the Size drop down menu, there is a concatenation of Designation, Description and Part Number.
I went to the family table and tried to make a custom expression to only show the Designation and it doesn't work.
Any idea how to clean the Size drop down menu up so it looks like the menu on the left?
Thanks!
Sean Farr
Product Designer at Teksign Inc.
Inventor 2016 SP1
Dell Precision 3660
i7-12700 @ 2.40GHz-4.90GHz
32GB DDR5 4400MHz RAM
NIVDIA RTX A2000 6GB
Shag_Bore
always happens, minutes after posting, solution comes outta nowhere,
during the publishing process, I like to include part number and description for when I place custom content parts directly (without using frame generator), this is where the concatenation happens, by re-publishing the part and only including the "Designation" , the drop down menu is clearer
Sean Farr
Inventor 2016 SP1
Dell Precision 3660
