I tried to install the "latest" language pack from this download site:
The file name for every language that I checked contains 2017R3. When I try to install the german R3 language pack, the installer refuses to do its job and tells me there is a newer language pack available at the above mentioned site.
So I tried to run the german web installer for Inventor 2017 and it tells me that if I just want to install the language pack I can do so from some path. However when I run the msi installer in that directory it complains about some missing dll. (see attached images)
So where can I find the appropriate german language pack for my Inventor Pro 2017.4.8 installation?
Solved by johnsonshiue. Go to Solution.
Hi! 2017 R4 update does not contain any language pack. In your case, I think you will need to uninstall 2017 R4 and then install German LP. Then install 2017 R4 again.
Many thanks!
