Where are the files going to in T&P
It seems like all the pipes are placed inside the project/workingfolder:
....\Inventor\Assembly2\AIP\Tube and Pipe\Run01
and all the elbows (and other fittings?) are placed in the CC files folder.
I like the way pipes are stored. Is that possible too with all T&P parts?
Cadmanto
See the attached link.
https://forums.autodesk.com/t5/inventor-ideas/possibility-to-change-the-default-file-location-for-ne...
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Mark.Lancaster
@Anonymous
Content center parts are stored based on the Tools/Application Options/File tab or the folder option under your active project file.   Not sure why you want to relocate your content center to the same place as your piping segments..   Basically you would be duplicating content center parts all over the place.
Mark Lancaster
To have no resolving issues, in case teh CC is unavailabke for whatever reason....
