When closing checked out file...no dialogue box to prompt check in...
Message 1 of 9
When closing a checked-out file, I used to get a prompt, something like "The current file is checked out; would you like to check in?"
I don't get this anymore and am wondering where exactly is this enabled?
Jim
Replies (8)
Message 2 of 9
Curtis_Waguespack
Hi gixxerjim,
Maybe you accidentally told it not to prompt again? If so you can go to the Vault tab on the ribbon in Inventor, and then click the Vault Options button. From there you can explore the prompt settings.
http://help.autodesk.com/view/VAULT/2015/ENU/?guid=GUID-9BF9C258-2288-4598-9D08-CA8DA65AD21A
I hope this helps.
Curtis
Message 3 of 9
Sofia.Xanthopoulou
Hi @Anonymous,
did Curtis_Waguespack's suggestion work out for you? Please share your experience with all readers.
If you need further assistance on this, please continue the conversation
Please create a new thread for other questions.
All the best for the New Year.
Message 4 of 9
I have found it sometimes prompts on parts, sometimes does not, and never prompts on drawings.
Message 5 of 9
Sofia.Xanthopoulou
Hi @Anonymous,
please check your settings against those : Inventor prompt.PNG
If this curious behavior still persists, please record it (e.g. with Screencast), maybe we can see something.
Please give us details about your configuration (Inventor, Vault, OS)
Thank you
Message 6 of 9
Sofia.Xanthopoulou
Hi @Anonymous,
just checking on the status here.
Did you get the chance to compare the settings? Still facing this irregularities with the prompts?
Please continue the conversation or mark/post the solution so all readers can benefit from your experience.
Thank you
Message 7 of 9
steveh5
Is there an upate here?
We just upgraded to 2017VP and the setting in Inventor is to always prompt for checkin when closing a file...
Agree this is a pain on large files (seeing it on all Inventor filetypes).
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
Message 8 of 9
mcgyvr
INV2020
I have noticed that if I don't save and try to close a file it will ask me to save THEN ask me to check the file in..
But if you save the file first then close that file it will NOT prompt you to check the file in..
Shouldn't it prompt to check the files in in either case?
The command is "on close".. not "on close if you haven't already saved the file"
Message 9 of 9
mcgyvr
Fixed my issue... Moral of the story... DO NOT UPDATE VAULT CLIENT without also updating the Vault Server to match.
I was not aware that their updates must remain in sync..
