Inventor Forum
whats the difference between group, composite and surface?
7 REPLIES 7
Message 1 of 8
shuaib_cad
3048 Views, 7 Replies
Untitled.pngwhat is the difference between group, composite and surface in COPY OBJECT option in ipt?????
7 REPLIES 7
Message 2 of 8
Cadmanto
in reply to: shuaib_cad
Does the definition in the help file explain it clear enough?
http://wikihelp.autodesk.com/enu?adskContextId=REDIRECT_IDD_PM_PROMOTE&language=ENU&release=2012&pro...
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 8
shuaib_cad
in reply to: Cadmanto
nope.
thats why am asking
Edited by
Discussion_Admin
Message 4 of 8
Hi shuaib_cad,
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0308-Parts308/0418-Construc418/0...
(see Copy Object under references)
  • Group: Copies/moves the selection set to a new Group in the construction environment.
  • Surface: Copies/moves the selection set to one or more base surface features in the Part Modeling environment. Creates one feature for each set of contiguous faces selected.
  • Composite: Copies/moves the selection set to a single composite feature in the Part Modeling environment.
I hope this helps.
Curtis
Message 5 of 8
plz .. what is the difference???
all does the same...
Edited by
Discussion_Admin
Message 6 of 8
Cadmanto
I think not only how it displays it in the tree, it is how it comstructs the geometry in the model.
Curtis,
That is the same link I gave him  Smiley Very Happy
Best Regards,
Scott McFadden
Message 7 of 8
Hi shuaib_cad,
As per the section in the help article noted earlier, a group copies the selected objects to a new Group and places them in the Construction Folder which resides within the Construction Environment. This means that to work with it, you must activate the construction environment first (keep in mind that there have been changes to this in Inventor 2013). A group can contain multiple faces and the faces within are left unstitched.
A surface is face shape bounded by edges. Copying faces as surfaces results in a new feature for each selected face. The resulting surfaces are left unstitched. Copying faces as a composite results in a single new feature containing all of the face selections.
Note too that if you edit a part file from an assembly file  you can use the Copy Object tool to copy as a Solid feature.
So while it might seem that the results all do the same thing, they each have their use for different workflows, depending on the task at hand. For instance, if we're doing some surface modeling we want a different result than if were trying to repair an imported model to make it a solid. There are also times when we use surface tools to create a surface as the end goal, and other times when a solid model is the end goal, and so the various options allow flexibility along the way.
I hope this helps.
Curtis
Message 8 of 8
He isn´t asking what each option in that function does, he is asking the difference between group, composite and feature. These terms aren´t exclusive to this inventor funcion.
@nicholas_machadoWKMTY - this post has been edited due to Community Rules & Etiquette violation.
