I am conducting a stress & modal analysis on an assembly. I omitted the bolts and corner supports from the study, therefore I need to represent those connections some other way. What is the best way to represent the bolts using Contacts?
I attached screenshots of my assembly along with the different type of bolted connections.
What is your goal?
Do you need to know how the structure behaves near the bolts?
Do you want to know the stress distribution in the thread profile?
Do you need to make sure the mass of the attached components affects the modal analysis?
Answering those questions will help you decide how to build your FEA approximation.
Steve Walton
Hi
If the analysis concerns the entire structure, it is best to disable the bolts and define connectors in their places (available in Inventor Nastran). This will simplify the construction, reduce the file size and speed up the analysis.
In the case of the strength of the screws themselves (more efficient), do it on a single file, and it is best to use the engineer's guide (also the one built into Inventor).
Kacper Suchomski
Thank you for your replies gentlemen @kacper.suchomski @swalton.
As a first step, my objective from the stress analysis is to analyze the entire structure, specifically the parts marked with a red arrow in this attachment, and determine how far we are from yielding with the current material thicknesses, and number of corner supports & bolted connections. In my current analysis, I disabled the bolts, and proceeded with the simulation by representing the bolts by bonded contacts (I think there is a better way, either a different type of contact or choosing the appropriate elements to bond with one another). @kacper.suchomski can I pull off what you recommended in the regular Inventor?
Maybe in another simulation, I'll look into areas around the bolts or stress distribution around the threads.
With regards to the modal analysis, I would like to examine the response of the structure to external vibrations excited by a fan motor resting on the blue rubber isolators/dampeners.
Here are my quick thoughts.
Steve Walton
Noted. I switched to Nastran's environment and will be using it for my FEA to account for the isolator's non-linearity and to use connectors in place of the bolts. I assume there will be no need to use bonded contacts anymore since I'm using connectors right?
You can choose from many types of connectors.
https://www.youtube.com/watch?v=dJosjb8yolk
https://www.youtube.com/playlist?list=PLtakexwsjr-BwSo7MiiZckbbgMaYhTioT
Kacper Suchomski
I used bolt-type connectors in Nastran, ran the model and got a singularity error at a node located on an unnecessary hole on one of the parts. I removed this hole in Inventor Pro, and when I came back into the Nastran environment, I got a warning saying all my midsurfaces and constraints have been lost: Face has been lost due to Part modification, even though I only suppressed one hole of one part out of 20 parts. I lost all my connectors as well. I then tried to Manage --> Rebuild All, then the software froze and crashed. I tried this multiple times and the same thing happened. Is there a work around for this? Without having to repeat all the connectors, it just doesn't make sense to have to repeat all of them every time a small modification is made.
