- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there,
I'm trying to rotate a small circle along the arc of another larger circle by selecting the center point of the big circle. However, the trajectory of the rotation is very strange. As seen in the pictures, the rotation follows the trajectory perfectly at the top and the bottom of the large circle, but is narrower at the sides. I thought that perhaps the smaller circle is offset a bit to the right but nope - it's closer to the center than it should be when rotated both 90 and 270 degrees. I was only able to post screenshots for 0, 90, and 180 degrees. Thank you!
Does anyone have an idea as to why this might be happening? Thank you.
FIXED: Sorry, turns out I was pointing to a point outside of the plane. I can't seem to delete this post.
