- Mute
- Permalink
- Report
I am creating a frame for a body on a vehicle, the members of the frame consist of box and rectangular box section and are assembled together using a simple L shape bracket with nuts and bolts. I have created an iPart for the L shape bracket, for two different sizes of the bracket (different hole spacings for each size) and amirrored version of the bracket.
Obviously I need the frame members to have the same holes as each of the brackets so I can bolt everything together. I want the holes in the frame members to be associative incase I need to change the position or size of the holes.
What is the best way of doing this?
- Create the holes in the assembly - Quick, easy no good for creating drawings of each part
- Create sketch on each of the frame members and project the holes of the brackets in the assembly - Works but creates lots of adaptive parts, i read somewhere that adaptive parts should be kept to a minimum? (probably when creating large assemblies)
- Create an iFeature for the holes, use this iFeature to create the holes on L shape bracket iPart and reuse iFeature to create holes on frame members - Have played about with this idea but not successful
- Extract iFeature from L shape bracket iPart to create some sort of Table ifeature and use ifeature on frame members?
My knowledge of iFeatures and iParts is quite limited but the best method has got to be something to do with using these tools, If anyone can share some knowledge that would be great.
Cheers, Joe
