What is "Adaptive"?
What is "Adaptive"?
Vagulus
What is "Adaptive"?
Vagulus
This icon appeared in a part I was working (unsuccessfully) on.
What is it telling me?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
CCarreiras
Cadmanto
Pretty good explanation in this thread.
https://forums.autodesk.com/t5/inventor-forum/what-does-setting-a-part-as-quot-adaptive-quot-really-...
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
johnsonshiue
Hi! Like experts have mentioned here, take a look at the two threads. If you don't understand Adaptive, likely you may not need it. I would suggest you turn off the following options so you don't see Adaptivity.
Go Tools -> Application Options -> Assembly -> In-place features -> uncheck both boxes for "Cross part geometry projection."
Many thanks!
Software Test Engineer
Vagulus
That's certainly my category.  I don't understand it, and I don't see any use for it (at present anyway), so I don't need it.  To avoid complications I won't even turn it off - I'll just ignore it.  At least I have some idea of what it means.
Thanks to all.
Albert Einstein
