Weld Symbol in wrong style
eedmondsHRMXH
eedmondsHRMXH
As video shows,
The ANSI weld symbol only works if the whole ANSI standard is activated.
I want to use the ISO standard but reference the ANSI weld symbol. After selecting the respective options, it doesn't work - it still uses the ISO symbol.
(view in My Videos)
James_Willo
Sorry if you explain this in your video, it's not processed yet.
If you want to override certain dimensions/weld symbols.
  1. Activate the Annotate ribbon
  2. Click the symbol first (or multiple)
  3. Click the far right bottom dropdown and select a different style
  4.
James W
Inventor UX Designer
eedmondsHRMXH
Unfortunately, that does nothing for me.
(view in My Videos)
James_Willo
Hi, in your video you are just changing the overall standard, the weld settings are under weld symbols at the bottom. You need to check which weld settings are being applied to each standard.
The standard pulls the settings from whatever is listed in default objects
James W
eedmondsHRMXH
In my first video, I show that changing these options does nothing unless the full ANSI standard is active.
Is there a way that you can do it?
James_Willo
Hopefully this helps
(view in My Videos)
James W
